repairing >
repairing
repairing
Old 08-11-2003 | 03:35 PM
Default repairing
Hi Guys
I have an ARF trainer that I need to repair. I punched a hole in the leading edge of the wing, damage was small but I have never put the covering on the the plane and there for I'm not sure as how to go about it. Should I just cover the area with the damage or should I cover a larger area around it?
Thanks for any help.
Old 08-11-2003 | 04:11 PM
Default repairing
Irish
On a trainer plane, which is bound to recieve more damage,one way or the other , I use the two inch wide clear packing tape , it is cheap, easy and strong,
Highlander
Welcome to RCU !!!!!!
Old 08-11-2003 | 05:49 PM
MinnFlyer's Avatar
Default repairing
Ditto. If the hole is small, just cover it with tape. If you want to use covering, cut a piece so there's about a 1/4 - 1/2" overlap.
Old 08-11-2003 | 06:43 PM
Default repairing
Ditto on the above. But if you are bent on using covering and the hole extends out to the ribs then cut away the punctured covering forming a square in between the ribs. Then recover leaving anyware from 1/4 in.- 1/2in to overflap the stock covering. But be carefull to not burn a hole in the stock covering during the operation.
