Any ideas for organizing a dedicated workbench/shop?
Having returned to the hobby after 20 years, Iam trying to organize a workbench to build/work on my planes. Since I am not the neatest, most organized person in the world (or in my own house for that matter), Iam asking for some help. Has anyone found any products that are very useful for organizing a workbench? Does anyone have any pictures of their workbench? Any ideas for organizing? I'd **really appreciate**any help. Thank you.
RE: Any ideas for organizing a dedicated workbench/shop?
The only thing that I can suggest from personal experience is bins. I tend to throw stuff into bins, I have several bins, one for engine parts, one for radio stuff, one for building tools, etc. I want to get more organized, but I know that I am bad about putting things back to their home, but bins work for me.
NJ
You may want to consider a work bench that you can access from all sides. That is, not placing the bench against any walls. IMO, it's easier to build when you're able to access the plane from every side. That said, the bins, compartments, etc. would be located a short distance from the bench, either mounted on a wall or on a second bench. Just a thought.
DaveB
DaveB
ORIGINAL: DaveB
DaveB
DaveB
We'll be relocating the shop in the basement soon and that will be a consideration.
My Feedback: (15)
TN
Must echo DaveB...a build table or bench in the middle of the shop is top notch.
Also, don't overlook wall space as airplane storage space. Some adjustable shelving/organizing systems available at Lowe's, Home Despot, $BIG_BOX_STORE will give you lots of ideas for hanging fuselages, storing wings, etc.I built mine from a SOLID CORE wood door (Hollow core doors tend to sag/warp), some 2x4 framework, some pieces of ply to create shelves/cubbies for covering/wood/etc, and then somecastersso it's mobile.
I've attached a few shots of mine for examples...
My Feedback: (15)
TN
ORIGINAL: stevenmax50
Nice. I am going to Lowes this afternoon to hang the 4 models I have now.
The beauty of using those brackets and rails is how adjustable everything is. It can be moved left, right, up, down, wherever you need...so, as you can see above, big planes, small planes, short, fat, tall, skinny, wings, you name it.
NV
Split bench. Half bolted to the wall, half on wheels so you can move it away for the wall and walk around the plane.
Ya I know, need to clean that bench tomorrow after I come back from flying.
WA
I kept loosing tools while in the middle ofprojects so I cut off the end of a 2X4 12" long and after taking inventory of all the bench tools I use, separating them into groups, I measured shank diameters and recorded how many holes of various sizes I needed to hold all the tools, I drilled holes in a neat pattern almost but not through the 2X4 completely.The result is shown in the pictures below and life is far easier now using this simple holder with my work area much less cluttered.
TX
i just got a new shed. It's great with enough room for both planes and a lawnmower. But the best thing is the peg board. Makes it very easy to organize anything.
And an old knife holder (the one that knives slide into } works great for dremel tools. Just drill a couple dozen holes in the back and put all your dremel attachments in it. Use the knife slots for files, rulers, etc.
