Canopy Glue >
Canopy Glue
Canopy Glue
Old 08-15-2003 | 10:05 PM
JEH
Default Canopy Glue
WHAT KIND OF GLUE SHOULD I BE USING TO GLUE A CANOPY TO A COVER FRAME.
Old 08-15-2003 | 11:19 PM
Fastsky's Avatar
Default canopy glue...
I prefer to use RC56 canopy glue. It comes out of the tube white and drys clear to a flexible vibration resistant finish. Its inexpensive, easy to apply, fuel proof and vibration resistant. It also holds like crazy and is fuel proof. The only down side is that it takes overnight to dry. If you use CA glue, some types make the plastic haze oever from the awful fumes!
Old 08-18-2003 | 04:17 PM
Default Canopy Glue
I've had great success with Goop brand glues. You can get it in most hardware stores. It comes in several varieties, but they are all pretty much the same. It has a ton of other uses as well.
