 Battery Size >
Battery Size
Battery Size
Old 12-02-2011 | 07:32 AM
Default Battery Size
I am getting a Sigg Senior back in the air, it has standard sevos, and a JR R921X receiver, what size battery do I need for the plane? I realize the R21X is an overkill but that is what i got with my radio.
Old 12-02-2011 | 07:47 AM
Default RE: Battery Size
I have a 1300mah NiCad in mine, mainly to help with balance. I would say anything 1000mah or over with give you plenty of flight time.
Bruce
Old 12-02-2011 | 07:55 AM
JohnBuckner's Avatar
I use this Super Senior (Nitro Planes) set up for exclusively for primary training with an OS .35AX and the servos are all Hitec 225 Mighty Minis.
If you are flying 72mhz then a four cell (4.8 volt) pack of 700mah's or better is sufficient.
If you are flying 2.4 then a five cell (6 volt) pack of 1650mah's or better is sufficient. These are what I reccomend and consider the minimums for the on board battery supplies.
You will enjoy your Senior, There has been no better trainer ever.
John
