Estimate flight time given RX battery size and servos
PA
ORIGINAL: acdii
I haven't given it much thought. For the planes I have flown so far, when the motor quits, it's time to land and recharge. I have to rethink that thought though, my next plane will have a gas motor, so I will need to get into the habit or recharging the RX and Ign packs.<div>
</div><div>I still haven't purchased the packs for the P-51. I discovered last night the RX for my Futaba will take 7.4 volts so I can use a 2S 25C 2000 mah pack for the RX. That will save some weight and give me quite a few flights, but want to stick with 4.8 for the ignition, too many reviews showing problems with higher voltage. </div>
ORIGINAL: kmeyers
Mranga
Are you using 4 or 5 cell packs?
Mranga
Iam using a 4 cell pack (4.8 volts). Why is this relevant?
ORIGINAL: billd76
you will love gas! long flight times and cheap fuel! well, cheaper than batteries or nitro
ORIGINAL: acdii
Ihaven'tgiven it much thought. For the planes I have flown so far, when the motor quits, it's time to land and recharge. I have to rethink that thought though, my next plane will have a gas motor, so I will need to get into the habit or recharging the RX and Ign packs.<div></div><div>I stillhaven'tpurchased the packs for the P-51. I discovered last night the RX for my Futaba will take 7.4 volts so I can use a 2S 25C 2000 mah pack for the RX. That will save some weight and give me quite a few flights, but want to stick with 4.8 for the ignition, too many reviews showing problems with higher voltage.</div>
This is another thread (not related to the original question)but what are the smallest available gas engines equivalent to (compared to an equivalent nitro) ? I understand they are much more reliable as well.
Ranga
PA
ORIGINAL: mranga
This is another thread (not related to the original question) but what are the smallest available gas engines equivalent to (compared to an equivalent nitro) ? I understand they are much more reliable as well.
Ranga
ORIGINAL: billd76
ORIGINAL: acdii
I haven't given it much thought. For the planes I have flown so far, when the motor quits, it's time to land and recharge. I have to rethink that thought though, my next plane will have a gas motor, so I will need to get into the habit or recharging the RX and Ign packs.<div> </div><div>I still haven't purchased the packs for the P-51. I discovered last night the RX for my Futaba will take 7.4 volts so I can use a 2S 25C 2000 mah pack for the RX. That will save some weight and give me quite a few flights, but want to stick with 4.8 for the ignition, too many reviews showing problems with higher voltage. </div>
Ranga
I have never flown for 45 minutes at a shot. but after 25 minutes, I still have over a 1/4 tank left.
#31
PA
ORIGINAL: mranga
kmeyers,
I am using a 4 cell pack (4.8 volts). Why is this relevant?
ORIGINAL: kmeyers
Mranga
Mranga
The very best battery info, period! This guy knows what he talks about and his batteries are the best. http://hangtimes.com/rcbattery_faq.html
#33
ORIGINAL: CGRetired
You can also charge the battery after 3 or 4 or 5 flights (depending on your courage) and keep things safe.
Pushing things to the point of exhaustion is not necessarily in the best interest of neither the hobby nor the the owner of the plane, not to mention the potential victim that could be hurt by something falling out of the sky that weighs about 8 pounds traveling at about 50 miles per hour.
Why push it? What's the point? It can't be just to get another flight because with today's fast chargers, we can be back in the air in less than an hour. So, bring two planes and charge one while flying the other, or sit down with your buds and have a conversation about RC flying... or whatever tickles your fancy.
The point is to keep things safe. We say this over and over again. A Sanyo 4 cell 700 ma pack costs a whopping $11.99 - http://www3.towerhobbies.com/cgi-bin...&I=LXFD90&P=ML as an example.
So, buy two. Check the voltage (personally, I use a voltwatch2) before and after each flight. If it's questionable, charge the battery... fly a different plane or pull the battery pack out and replace it with a fully charged pack and charge the one that you pulled out.
CGr.
CGr.
#34
ORIGINAL: mranga
1. Full size servos will draw about 250 ma of current on average (OK I know the peak can be much higher and the at rest current draw is much lower). Is this a good working assumption for a trainer type airplane ( should I assume less or more ?)
Ranga
Ranga
If not you are underestimating.
A standard servo can pull down 2000mA at full stall. Ideally that should NEVER happen, but 250mAh and above is fairly normal at higher deflections.
At rest the load drops down to a small fraction of that.
Put a meter on your pack and move ONE control surface, say the elevator... while holding it like this, put a 4-8oz weight on the trailing edge of the surface and see how much draw you are getting from the servo... you will be surprised!
IMHO you should calculate a minimum pack size for a standard servo by taking 250mA x the number of STD servos used, to give you a good safety margin and proper duration for 4-6 flights without worry.
#35
My Feedback: (-1)
ORIGINAL: raptureboy
Constantly recharging batteries before they get down to a cut off voltage is not good for them either. The best way to know the condition of your batteries is to use a loaded volt meter of a least a 250 mAH load for sport planes and 500 mAH load for giant scale or 3-d planes. Also you need to load test your batteries periodically on a charger to know what they are capable of. As a general rule once they deliver less than 70% of their rated capacity they get replaced. Again the best battery FAQ out there: http://hangtimes.com/rcbattery_faq.html
ORIGINAL: CGRetired
CGr.
CGr.
#36
ORIGINAL: opjose
I hope you are assuming 250mA for EACH servo average under flight loads when NOT at stick center.
ORIGINAL: mranga
1. Full size servos will draw about 250 ma of current on average (OKIknow the peak can be much higher and the at rest current draw is much lower). Is this a good working assumption for a trainer type airplane ( should Iassume less or more ?)
Ranga
Ranga
Correct. I am assuming 250 ma per std servo and 100 ma per micro servo, giving me a total draw (for this plane)of 550 ma. Thus, an estimated flying time of about 1.75 hours.
Thank you for responding,
Best regards,
Ranga
#38
ORIGINAL: opjose
Very good!
What size and kind of plane is it?
Very good!
Opjose,
I made a mistake : 2 standard servos x 250 ma +3 micro servos x 100 == 800 ma. So I'll get about 1.25 hours of flying time with 1000 MaH. Safe to go 4 flights at 10 minutes each flight.
The plane is a biplane ( 40 size with micro servos for the aleorons and for the throttle ).
Ranga
#39
ORIGINAL: DustBen
I have to warn against the idea above.
The flight loads under speed exerted upon ailerons, elevators, and the rudder greatly increase the resistence to movement. Assuming battery consumption in flight is the same as static loadings is not accurate.
I fly some pretty light designs and have some relatively tiny flight batteries.
The way I determine the mAh size I need is to start with a robust battery around 750 mAh. I fly the model wildly... consuming about as much as I can.
As quickly as possible, I check the ''end of flight'' voltage (this is critical because a battery can rebound and if I check the voltage 30 minutes after flight, the voltage will read much higher than the actual, post-stress voltage).
I then carefully recharge the battery and observe the amount of mAh it took to restore full capacity.
Meanwhile, I begin downsizing the battery. I drop to 600 mAh and repeat the careful monitoring of mAh consumption and voltage.
Once I determine a specific ''consumption'', I get a battery of slightly larger mAh capacity and begin using it. I fly shorter flights at first, always checking the health of the battery at the end of the flight.
While I understand every bit of being conservative with flight packs, I also hate putting a 6.7 ounce battey into a 2-3/4 pound model when I can safely get by with a 40 gram 350 mAh pack.
ORIGINAL: jimmyjames213
Instead of guessing how long a battery will last and how much the servos draw, just test it?????? Sit on the couch and move your ailerons and elevator while watching TV. Start the clock when you first start moving the sticks; stop the clock when the battery dies. When your battery finally dies, divide that by your flight time, and that’s how many flights you can fly on that battery. There is already a huge % error built into this method, the fact that your control surfaces are moving nonstop, what this means is if your flight time is 10 min and your battery lasts an hour you can safely get six flights in. Realistically that battery would be fine for 12 flights due because I doubt a trainer is constantly doing rolling circles, but cut it in half to be safe and you should be good to go.
electricity can be hard to understand and trust for some, the easiest way to understand it is to see it in practice. Instead of guessing just test it, if your battery lasts an hour of constant elevator/aileron servo opperation (just move the gimbals around the corners) and you know for a fact you are not doing that in the air, then you should have plenty of juice for 6 flights at 10 min per flight
Just a warning, small batteries can’t deliver high current. Most 350mah nimh batteries are good up to 2-3 amps, go over that and your voltage drops like a rock.
#40
I agree that the static load will not equal the dynamic loads; however this should give a rough estimate. Bad batteries would quickly be recognized with this method, and assuming you took voltages every 10 min you could compare your inflight numbers to the “recorded data” and find out how close (or far) the method really is. The point I was trying to get across is batteries last longer than you think, but always compare battery voltage to known data
As I said, I am flying some pretty light designs.
Having said this, I have some 1500 and 1800 mAh LiFe packs I haul around in trainers and put in 45 minute flights with students and don't worry a bit about battery capacity.
#41
Disregards servo when no load I'm mean when it's on the ground. Timer start from taxiing to engine shutdown after landing. Actually your servo load is based on the size of your control surface and speed. also weight of an aircraft affect energy requirements. Considering your data, take the ff:
milliampere hour requirements, mAh
mAh = average current consumption of all servo * time * 1000 * 1.25
time = flight time in hours
Power requirements = servo voltage * (full load current of all servo + 25% of highest pair servo current) / 80%
Let me know if you have any question.
#43
All of the aboveis good advice. Know your batteries capacity and the usage of your plane. I have an easy method that has worked well for me.
Cycle the battery a couple of times and fully charge it. Make a resistor lead for your volt meter(I use 20 Ohm 10 Watt). Test the voltage of the fully charged battery after a few seconds of load when the voltage stabilizes. Leave the load on it and record voltage every 5 minutes until the voltage falls rapidly. If you graph the results you will see the voltage drops very slowly over its capacity, and falls off at the end. Back up 10 or 15 minutes from where it begins to fall off and mark this voltage on the pack. Test the voltage every flight, and Do Not take off when the voltage reaches this point.
You will find out very quickly how many flights you can get out of a fully charged pack. Remember, Nicd batteries have a memory, and they do not like to be partially discharged and recharged. You can charge at the field if you need to get a few more flights, bud it is better for the battery if you don't. From the sound of it, you are not even using half of the capacity of your batteries.
#45
My Feedback: (7)
ORIGINAL: Gray Beard
A volt meter with a load is a good thing to have. I check my packs before each flight then usually check before each flight after that. When I get close to say 4.8 volts then I put the pack on a field charger and start the process over again. On those real lazy days I check before the first flight then on the third flight. My flights last about 10 minutes and I get about 5 flights per charge. Even if I have enough juice left in the pack I put it on the charger. Most of my servos are digital and all of my planes are stunt planes of some sort, I don't have a float around plane at the moment. I only take the trainer out when I have a student or the wind is up. My packs are all nim
#46
I would base the battery size more on weight than electrical capacity... I would never fly a 600mahr pack when the weight of a 2300 pack is almost the same.
I never fly 4.8 batteries ... I have switched entirely to 6 volt 5 cell batteries. More head room before a brownout. One crash due to batteries and you will start thinking the same.
I never run a NiMH down to zero. When the charger says I have put 2600 mahr into a 2300 mahr battery (example), I know that it cannot be because of losses and heat produced, therefore when I put 1800 mahr into a 2300 mahr battery I know that did not happen either.
I know weight is important, but flying safely with more battery power than necessary is more important.
#47
The best advice I could give you is to PM Red Scholefield. Red knows more about batteries than probably the total of the rest of us have forgotten. The key is to "do what he suggests".
#48
hi
i only use NICADS for 20 plus years in two cycle glo planesonly batteries there were 20 years agonever a battery issuewith proper maintenance
if the battery cycles twice every 2-3 months i will fly it if it has not lost 20 % of its capacity
always cycle a new battery 2-3 times to bring up its capacity ( this is the number you will deduct 20% from in the future )
do not care how old the pack is it has passed the required cycle testI FLY IT
slow charging is always best
keep NICADS fully charged when storedprevents shorts
find that the peak chargers i have used have shortened my battery pack life a lot over slow charging at 10c or trickle charging which is best
fast charging is damaging your best cell in a packas that cell is almost at a capacity charge when you start the charging
you will feel the servo's get slower -when the battery gets weakeras you are flying the plane learned this from my trainer flying for 30 years
get my best results charging NICADS with a wall chargerand cycling with an ACE DIGIPACE- went back to doing what i used to do after using a peak chargerthat truly shortens battery pack life far to much for my liking
BEST REGARDS TONY
BEST REGARDS TONY
#49
Tony here is some battery advice I got off the net. Dan.
http://www.camlight.com/techinfo/techtips.html
#50
*Q: What’s ‘cycling’ and why do I need to do it?
A: Battery‘cycling’ in it’s simple form is the two step process of charging and then discharging the battery under controlled conditions. Normally the purpose of the procedure is to ‘condition’ or ‘format’ a new pack or to verify the capacity or check the condition of a pack that’s been in service. ‘Routine’ cycling, or discharging before recharging a pack after every use is not necessary for either NiMH or Nicad packs, and discharging to ‘zero’ voltage under load is in fact harmful. A ‘cycler’ or controlled discharger will limit the discharge voltage level to prevent damage to the pack, whereas ‘leaving the switch on’ in your radio system to discharge a pack is very poor practice and may result in damage your radio system components or the battery.
Most ‘hobby’ cyclers or dischargers operate at a predetermined load and cutoff level that is different than the cell mfg’s rating system. This leads to discrepancies that can be a high as 10-15% of rated capacity between the mfg’s rating and the rating presented by the cycler or discharger you are using. If your cycler or discharger system’s numbers are lower than the comfort zone described above then you need to verify the calibration of the cycler and check the charge rate and charge time to insure the pack did indeed get a full charge before the discharge function began. If the numbers are still uncomfortably low after re-running the test with your new pack, we suggest you contact the assembler or retailer for evaluation assistance in determining what the cause is before using the pack in a critical application. Any pack cycling more than 25% below the mfg's rating or the original numbers established for the pack with your equipment when it was new should be removed from critical application service.
Q: How do I know if my pack is fully charged?
Temperature is the key.. always, always, always! IF THE PACK AIN'T WARM AT THE END OF THE CHARGE ROUTINE, IT AIN'T CHARGED! Note I said 'warm'. Not HOT! Hot is NEVER GOOD at the end of the charge routine.. but warm is OK. If using a temp probe, set it for 10 degrees above AMBIENT. If it's a peak controlled charger and the charger shuts down before the pack is slightly warm to the touch.. IT AIN'T FULLY CHARGED. If it's a timer controlled charger and at the end of the charge period the pack is not warm.. it's NOT fully charged yet! By far and away the biggest reason for low capacity numbers is undercharging.. if you have a 5 gallon pail with only 3 gallons in it, your only gonna get 3 gallons out of it. Engage your brain.. check temperature at the end of the charge routine!
Q: Temperature?? I thought voltage was how you could tell the pack was charged??
A: More packs have been fried by guys looking for a 'number' instead of temperature on a charger than any other cause of premature battery failure. The 'finish' voltage of a pack will vary under an astounding number of variables.. but temperature rise ALWAYS signals that the cells are charged in a slow charge routine. Why? Because when the cells can no longer absorb the energy being shoved at them by the charger, they begin to give the unstored energy off as heat.
Taking the Temperature story to the next level.. fast charging. Here we can generate even more heat. Some high-impedance cells like AA NiMH's can get warm when being charged at 'normal' 1C (fast) or even 10% (slow) rates. They can get warm BEFORE they get to full charge. Why? Because high-impedance cells don't absorb energy as efficiently at high current levels.. just like they don't give up energy efficiently at higher discharge rates. So.. before you crank up the current on your charger on your new NiMH Txpack.. check the pack label on our packs.. and set the charge rate recommended; which is often LESS than the 'industry standard' for NiMH cells.
Final word on temperature: Aside from being a key indicator for correct charge time, rate and final charge condition bear in mind that heat is the bitter enemy of NiMH Cells. Drive the pack into thermal overload (hot) on the charger and it's likely you'll ruin it. Pay attention to the temperature!
Taken from http://hangtimes.com/rcbattery_faq.html
