What Servo?
G`Day
Can someone please advise me on what servo I could use in my Phaeton 90 Wing? Am doing away with the single servo located in the centre of the wing (as the plans show) and opting to install servos in the wing to run my ailerons. Do`t wish to use Futaba, am using Spectrum receiver.
dutchy50
dutchy50
<span style="font-family: Verdana, Arial; font-size: 13px; -webkit-border-horizontal-spacing: 1px; -webkit-border-vertical-spacing: 1px; ">G`Day
dutchy50 <span style="font: normal normal normal 12px/normal Arial; color: rgb(36, 36, 36); " class="info"></span>
<font color="d4d4d4" size="1">Hide Signatures</font></span>
If you're now using 2 servos instead of one use the servo called out for in the instructions....that will be plenty....just make sure that both servos are the same brand and same model number
ORIGINAL: dutchy50
G`Day
dutchy50
G`Day
dutchy50
You will find that many tell you you have to have such servo and must have this servo and that is all BS. I still fly large airplanes (One a bipe at 101" w/s) with old Hitec 605 servos. Flies well. Another 101" w/s model flies well with analogs. I don't do 3D so it doesn't matter.
