need help >
need help
need help
Old 09-01-2003 | 05:06 AM
550racer's Avatar
Default need help
so basicly take my engine to a instructor and have him test it to see if it runs? is there anyway i can test witout runnin it to tell if everythings workin properley?
Old 09-01-2003 | 12:16 PM
blue62's Avatar
Default need help
yes when u turn the prop does it have a good compression? it should have a springy tension feeling to it followed by a sort of pop noise out the exhaust
if it does then it probably will run!
john
yes most club members will test run it for you though they might have to take it home with them to mount it on a test bench. if its a 40-46 sized engine i would put a 10-6 prop in it before you go just so it has a propellor and they don't have to dig one up.
good luck and welcome to the addiction!
Old 09-01-2003 | 03:49 PM
550racer's Avatar
Default need help
yup its got that with a lil pop its not really springy but its springy
Old 09-01-2003 | 03:55 PM
blue62's Avatar
Default need help
sounds like arunner then!
mount it in the plane and take it to the club and i bet somebody will get it fired up for ya!
good luck
john
