Spinner for trainer >
Spinner for trainer
Spinner for trainer
Old 09-06-2003 | 01:53 AM
Default Spinner for trainer
I just put a two blade prop on my alpha trainer, but it doesnt want to fit right. It is a 2 1/4 spinner but the evolution engine conversion back plate does not want to fit the spinner. If anyone has converted their trainer to a two blade prop, please provide me with some info.
Old 09-06-2003 | 02:37 AM
I would put a new spinner and back plate assembly on the engine rather than using the old one that wont fit. I am not quite sure what the problem is, but that is what i would suggest.
Old 09-06-2003 | 03:01 AM
jettstarblue's Avatar
I converted mine right away. Use a new backplate, the one that came with the 2 blade spinner.
Keep the flywheel on the engine, use an 11X6 prop.
Jetts
Old 09-06-2003 | 03:40 AM
Im sorry, I should have explained it better. I meant that I took the flywheel off because it would not fit the dubro spinner. So I bought a evolution replacement prop driver but it does not fit flush with the spinner backplate. I didnt know what everyone did when they converted to a 2 blade prop. Jettstarblue, mthe flywheel will not fit with the new spinner, how did you do it.
