officially back in rc
I'll respectfully disagree about putting loose Nimh's into a 4 cell battery holder. 99% of the time that works just fine, but you're relying on the spring tension of a part made in China by 8 year olds who work for $1 an hour for the safety of your airplane. If a cell vibrates out of place or one of the springs isn't as tight as it should be, you take your plane home in a garbage bag. SNIP .
You don't remember me probably but I was a member when I was 11 years old. I had the Goldberg kit and the j3 cub and I beleive you helped me with my Aerostar .40 wing dyhedral brace back then. What a small world.
NM
I have been flying large heli for many years and just now building a trainer nitro plane, and you probably have settled on a decision.
I will say this, I have never had good luck with nimh batts they self discharge and generally have been unreliable in the helis. BECs from the motor to the radio servos ( electric powered helis) also can fail dropping volts to the RX in flight.
A123 batts are my best option and will power all my helis and future planes here is some good info on them.
http://hangtimes.com/a123_batteries_for_giants_faq.html
