Striped Covering >
Striped Covering
Striped Covering
Old 09-22-2013 | 06:12 AM
Default Striped Covering
I just came into possession of a Super Chipmunk.
I am looking for some striped covering for it.
I know checkerboard covering is available, with lot's of choices.
Does anyone make a striped covering? Prefer red & white.
KW_Counter
Old 09-22-2013 | 07:01 AM
I have not seen any covering that comes in the red and white stripes. On the two Chipmunks I built I just used red and white strips and ironed them together them iron the made up sheet onto the wing. I used a 1/4 inch wide piece of spruce to ironing the first piece down, then just ironed on the second piece, rinse and repeat over and over and over until you have enough to cover the section.
You could cover it in white, and use the windex method with the red pieces.
Buzz.
Old 09-22-2013 | 07:38 AM
i used this http://www3.towerhobbies.com/cgi-bin...?&I=LXHY13&P=7 it works well on flat surfaces. i used it on the top of the cowl and there are wrinkles.
Old 09-22-2013 | 09:16 PM
Nice Chipmunk!
I am familiar with that product.
I have blue I use for patching my Super Sportster.
Thanks for the suggestion.
KW_Counter
Old 09-23-2013 | 07:54 AM
AMA 74894's Avatar
Moderator
tough lon available from Airborne models in california ..
(wings maker and the world models distributor)
Tel: 925-371-0922
or email [email protected] .. Fai the owner is great to work with.
they've got all sorts of checkered and striped patterns.
