Converting servo torque in kg to ounces
How is this calculation done? for example.......
Torque: 33.5kg/cm @ 6v taken from http://hobbyking.com/hobbyking/store...8s_39_8kg.html
ok there is 2.2 pounds per kg.. so 33.5kg x2.2=73.7 Lbs then x16(ounces in a #) and i get 1179.2 ounces....then what do i divide by or am i doing it all wrong?
You also have to take into account centermeters. Converting them are part of the equation.
Here is an easy way, http://www.convertunits.com/from/kg+cm/to/oz+in , the answer is 465oz/in
I personally don't like HK, note I said "I". Take a look at the Savox seros, I have been running their SC-0251
Savox SC-0251 High Torque Metal Gear Digital Servo-savsc0251mg
Map Price $40.99
Dimensions(mm): 40.7X19.6X42.4
Weight(g): 61.0
Speed(@4.8V sec/60): .20
Torque(@4.8V oz-in): 180.5
Speed(@6.0V sec/60): .18
Torque(@6.0V oz-in): 222.2
Gear: Metal
Bearing: 2BB
Case: Plastic
25 Tooth Spline
Frequency: 200-250hz
Pulse Width Frequency: 1520
And love them.
Map Price $40.99
Weight(g): 61.0
Gear: Metal
Bearing: 2BB
Case: Plastic
25 Tooth Spline
And love them.
+1 on that, not once have I seen a user of the Align (Savox) DS610 servos or any of the other high torque and speed servos from Align ever complain bout them. If you ever ask "what servos to use on a 600-700 size heli" in a heli forum, over half will suggest either the Align DS610 or DS620's.
what a small world...there has been times where ive beem researching RC related stuff, ill run into his website, it's very helpful, thanks ....its nice to know he is here on RCU
FL
Ah... forget it. AFM = Airfield Models. Never heard it referred to like that before. I'm a bit dense.
Thanks guys.
I haven't finished a plane in forever so I'm hanging around here a lot trying to get motivated. Just got two brand new Herr Pitts Specials - one of which is going on my board very soon. I'm playing with engines here at my desk to figure out if I can make them interchangeable. Already know the OS CV-A is great but also have a NovaRossi .12 (0.7 ounces heavier but maybe a lot more RPM - we'll see).
Details will be on the site eventually.
Sorry for the hijack, OP.
Thanks guys.
Tower Hobbies site has a very useful conversion tool.
Linear Conversion Calculator
Area Conversion Calculator
Volume Conversion Calculator
Weight Conversion Calculator
Torque Conversion Calculator
Temperature Conversion Calculator
http://www.towerhobbies.com/help/convcalcs.html
I keep it very close when shopping, just copy paste into it and hit calculate
Ken
Ken
What's an "AFM"? I'm new to this web stuff.
