Seagul Ultimate bi-plane arf
new to this site but not flying. im used to the foamy planes and I have a couple nitro planes. I just got me a ultimate bi-plane and I would like suggestions on what type of metal gear servos would be best , and what engine would be best I know that I want to do a 4-stroke in this plane and not a 2 stroke. any help with what I should get to build this plane right will be greatly appreciated.
thanks pat
thanks pat
http://www.horizonhobby.com/products...90-arf-SEA5050
[h=3]Needed To Complete[/h].91–1.25 2- or 4-Stroke Glow Engine
Glow Plug (Engine Specific)
Silicone Fuel Line
6-Channel Radio System with 6 Digital Servos
Propeller
2.75" (70mm) Spinner
Probably the largest 4 stroke you can buy to put in it, you don't want to go too large, the weight penalty will offset the power gained and make it somewhat difficult to balance.
http://www.horizonhobby.com/products...EA5050#t4-KITS
This is the recommended completion kit, you don't have to buy their servos, but look at the specs and try to find the equivalent from somewhere that suits you. The recommended 125 is an animal, and once broken in, should haul you around with no problem. Make sure to completely epoxy the firewall to avoid failure in that area.
Silicone Fuel Line
Propeller
heres what I have so far , futaba s3004 servo for throttle, hi tec hs 465 mg for aile, rud, and elev, spectrum ar6210 receiver, mpi on/off 3 led battery switch. trying to decide on what engine either a saito or an OS I do know I want a 4-stroke, ill get me 2 batteris later this week and my wire extensions and y plug for the aile
IL
I know you want a 4 stroke, but I have a OS 1.20 AX and I have no regrets. It's a monster. And it balances nicely with a receiver battery just behind the firewall. I use hitec 645MG servos in my bipe.
My Feedback: (29)
You just can't beat a YS 110, 115 or 120 for that type of airplane. Great power, easy to tune once you get the hang of them, they allow you to place the fuel tank on the CG and if you need assistance tech support is fantastic through YS Performance and there are a bunch of guys here on RCU in the scale racing forum that easily have a combined 30 years of experience running them, the pattern guys have a wealth of knowledge as well.
Moderator
I've got half a dozen YS four strokes, (all better than 10 years old) they are powerhouses and NOT terribly finicky once properly set up.
