Maximum prop size diameter for Sig 4 Star 60? >
Old 08-30-2014 | 06:13 PM
Default Maximum prop size diameter for Sig 4 Star 60?
Might be putting a VVRC 20cc gas engine in a Sig 4 Star 60 and wanted to know biggest diameter prop that it could take without without causing ground strike problems.
Old 08-30-2014 | 06:35 PM
foodstick's Avatar
You can always go with slightly taller wheels and landing gear to put on larger props as well "and 3 bladed props". I have a Sig Senior with a 16-8 on there so it can be done !
Old 09-01-2014 | 05:43 PM
tacx's Avatar
Pretty simple, really. Just measure from your engine prop shaft to the ground. Unless I'm missing something?
Old 09-02-2014 | 12:41 PM
My Feedback: (-1)
i just did this a few minutes ago while putting the finishing touches to a repaired plane. I changed out the landing gear, already had the smallest prop I could use on the engine. When I put it on the ground and raised it to level I only had about a 1/4 inch clearance. Going from a set of 2 inch tires to 3.5 fixed the problem. Last $* 60 I built used a Saito 100 and I used a 14 inch prop but that was about as long as I could go without changing the tires. Been a while and it may have had more clearance then that?
