Beginner help for Gamma 370 >
Old 03-22-2015 | 07:11 AM
Default Beginner help for Gamma 370
Hello all. I bought an Ares Gamma 370 RFR yesterday and assembled it last night. I am using a Spektrum DX6i transmitter and a Spektrum AR400 receiver. I have a couple of questions. First, I'm not getting any propeller movement until the throttle is at 1/2 and on the elevator, I'm only getting approximately 1" of total movement horizontally. Is this normal for this plane and set-up or do I need to make some adjustments via the transmitter? The instruction book is almost entirely geared toward the RTF version. Thanks for any help you can give me.
Old 03-24-2015 | 06:25 AM
Moderator
An inch of elevator travel is a lot on a plane that size. My .40 size Cub is just barely over an inch of total throw, and it's over double the size. Does the manual have a recommended throw setting? I think you'll probably find that the plane is much more comfortable to fly down around 1/2 inch of total throw once it's trimmed to fly straight and level.
As for your motor, I'd call the manufacturer about that. If you have 100% throws set in the transmitter, you should get some prop movement at very low throttle settings.
