Spinners
Is it common to remove material from the prop openings in the spinner to allow you to assemble the spinner with it's back plate? I have not been able to put it on? It's a Dubro 2" plastic Spinner. If I ever get it back on I will have to take it apart to balance it again. I have to be doing something wrong?
Some propellor brands and/or sizes need larger cut-outs than some spinners provide. Tru-Turn, for example, will cut their spinners to fit your specific prop. You can try a thinner prop, a different spinner, or enlarge the openings on your existing spinner. You do need to worry about the balance of the spinner though. Keep the cut-outs as close to the same size and as symmetrical as possible and rebalance when your done.
Thanks for your response! I hacked away at the openings yesterday just to clear the prop. When I get to my shop today I will make sure both openings are alike. I have sufficient clearance now but still can't snap it together. I'll try some different brands.
I gave up trying to install the Dubro plastic spinner and got a Great Planes spinner with an aluminum back. Opened up the prop openings, made them both the same, balanced it and installed it without any issues.
