Removing paint >
Removing paint
Removing paint
Old 07-11-2016 | 04:12 PM
Default Removing paint
I'm trying to remove the paint that's on the canopy. The canopy is a clear, soft plastic and not stiff at all. I tried acetone on a Q tip which removes it but dulls the plastic beneath. I'll replace the paint with tape when done. Any thoughts?
Old 07-12-2016 | 06:12 PM
Hydro Junkie's Avatar
I would look for a "safe" stripper. I know there are strippers that are made for things like FG, so you might check with a supply house that sells various types of paints and strippers.
Old 07-13-2016 | 04:57 AM
Thanks for your response! I'll see what they have.
Old 07-14-2016 | 06:41 AM
TomCrump's Avatar
I'd replace the canopy.
Old 07-14-2016 | 02:20 PM
It's an old Sportster kit and no longer available. I looked around for a replacement without any luck. Thanks for responding!
Old 07-15-2016 | 02:48 AM
Would it be possible to use it, filled with something like plaster, to use as a plug to make more? Vaccuforming might be an option though you would need to make a more durable pattern
Old 07-15-2016 | 05:07 AM
Bill Diedrich's Avatar
If it is a Sig Sportster, canopies can still be had from Sig, however if it is a "Sportmaster"
a canopy is available from Lazer-Works, http://lazer-works.com/john-burke-sportmaster-3.jpg
Sportmaster
By Lou Andrews
Wingspan: 65 in.
.50/.90 2 Stroke
4 ch. radio
Canopy available for $15.00
Old 07-15-2016 | 02:39 PM
It's a Great Planes "Sportster". I've got the canopy pretty scratch free using "Mothers" plastic cleaner. I just might use some black trip tape over it. ??
Old 07-16-2016 | 05:26 AM
TomCrump's Avatar
If so inclined, the canopy could be painted. That's what I did on mine.
Old 07-17-2016 | 02:51 AM
Nice job Tom! I've got an instrument panel and pilot in the cockpit so would like to see my work. Thanks for your comment and foto!
Old 07-17-2016 | 08:09 PM
Pylonracr's Avatar
Tartar control Crest toothpaste will work. It will require some elbow grease though. Take your time and it will not harm the plastic.
Old 07-18-2016 | 04:47 AM
Thanks for responding and your tip!
