Binding Carbon Cub S+ >
Old 12-24-2017 | 06:47 AM
Default Binding Carbon Cub S+
I am hoping that someone has had this problem and can help me out. I have a Carbon Cub S+ that was RTF, I wanted to bind my DX8 and went thru the procedure and I just could not make it work.
I went bask to the Spectrum transmitter that came with the package and now I can't get it to bind.
I have tried inside, outside, in the middle of a field and I can't sort this out. Any help would be great, thanks.
Old 12-30-2017 | 07:26 PM
Stickslammer's Avatar
I have a Sport Cub S that I had trouble binding with my DX6 a couple times. Once I was too close to the airplane and after I backed up a few more feet it bound ok. Another time I think it was the power up sequence. Rx first then Tx or vice versa. Try these if you haven`t already. You could also try the Radios, Receivers Mfr. Direct Support sub forum near the top here.Hope this helps.
