optokill ignition kill or kill for coil ignition
Hello I have a older plane with a G62 Zenoah that has a coil/magneto style ignition system .
it has a kill switch /toggle , but I would like to be able to shut down from the transmitter .
I have 3 new opto kill units but do not know how to wire them for this application or if they will even work with the coil/mag system
I don't know a thing about the G62 engine. This is just a thought. Since you have a mechanical kill switch, a modification may be possible. Wire into the toggle switch circuit a micro switch. The micro switch can then be activated by a servo. Install the mod on a servo tray so all components are solidly attached.
The micro switch should be a normally open switch. This allows the ignition to function. The servo closes the switch which grounds the circuit shutting down the engine. This is all an assumption on my part as I think this is how the engine ignition would work.
A test trial on an an engine stand will let you know if this is a viable option. Keep safety in mind. All components MUST be properly installed and flawless in operation. Again just a thought.
You can do the same thing with just a servo alone. Simply remove the toggle and insert a servo in its place. One end of the wire to the toggle gets soldered to an inverted "U"-shaped brass plate epoxied to the top of the servo case. The other wire gets soldered to a brass strip screwed to the servo arm. This strip is "L" shaped with the short end of the "L" curled under the servo arm and makes contact with the brass plate when the servo is thrown to the closed position. Secure this second wire along the servo arm to provide strain relief for the solder connection.
Just use an electronic RC switch. There will be no moving parts or mechanical connections to fail. It will be lighter too.
This is one example out of many. ServoCity may be able to point you to other options as well.
https://www.servocity.com/micro-pwm-switch
