Futaba Server Tray
The new Futaba 6EXA radio comes with a server tray with a 4 plastic mounting posts per server. The necessary plastic hardware is there to mount these all in place and the servos can ride the mounting posts.
Meanwhile in the radio installation instruction it says that all servers must be mounted with rubber grommets. Six are supplied. I can see using these to mount the servo tray to the plane but not the individual servos - at least not with all these posts in the way.
Back on the wing there is already a wood frame in place for the servo. Is vibration less of an issue on the wing?
I opened the other package and found lot's of rubber gromets that fit on the rails. I'll use these on the wing as well. Sorry about that.
