Building board for kit?
Hi All
I built an Eagle II about 30 years ago and now I'm getting ready to build a Kadet. I was wondering what everybody's favorite board is to build on? Last time I used a ceiling drop tile, but the two closest hardware stores in my area don't carry them. One of them even warned me to call ahead to Home Depot in the city as they may not have them either.
What's a good alternative to a drop ceiling tile? I bought a 35x23 cork bulletin board last night only to discover that the fuse won't even fit on the board. I may just return it and find something more fitting.
Thanks!
Thanks!
Check your various building supply places for "Homasote 440". Home Depot does not list it. It's a fibreboard sound deadening material - perfect for holding pins. You can get it as large as 4x8. Many places sell pre-cut smaller pieces, also. Inexpensive, easy to cut to size, if you need to.
FYI, I ended up salvaging a 48"x24" piece of 2" thick Styrofoam wall insulation and am using that for a building board. It may not be the best, but it was free and that's good enough for me.
Also very important is having a building board that is flat and straight. A hollow core door works, but you may have to build a frame to straighten it. Then you can lay your homasote on top of it.
I use a solid core door and using drywall screws to attach the homasote. The drywall screws allow the two different materials to expand and contract without warping the door.
Thank you again everybody; next week I will look into purchasing some homasote; I already have several spare hollow core doors from my days of construction and remodeling. Today I added a second 48" light fixture to my work shop so that I could see the plans better. One step at a time.
