Brownouts ? I think
Good day, i bought a car on cub a few months back, destroyed it learning how to fly and have gotten to the point where i dont use SAFE and its always in expert mode. So i upgraded my transmitter to the DX6 for the display and voice commands. Upon ordering that i ordered the GPS telemetry module as well.
Havent crashed my plane in at leat 20 flights and since switching over after take off about 20ft in the air i loose everything for a second or two. Well say the least it nosed diver straight into the ground twice. I would of thought the safe would have pulled more power than this receiver and module are pulling. Range test at 90ft doesnt go under 60% starting at 75% for low voltage range test.
Its set up to 22m/s not 11m/s the Dxe transmitter was set to. Could this be the problem?
Im running 3s 2200mah lipos. stock 18a esc.
Thank you
Mike
Thank you
Mike
