 PAYLOADS >
PAYLOADS
PAYLOADS
Old 09-29-2003 | 03:23 AM
Default PAYLOADS
how do u explain the differences in the payload of the aircrafts
Old 09-29-2003 | 05:50 AM
MinnFlyer's Avatar
Default RE: PAYLOADS
Huh???
Can you explain a little better?
Do you mean: Why can some planes carry a larger payload than others?
Old 09-29-2003 | 05:58 AM
Welllll some cary more weight and the others don't..........
Old 09-29-2003 | 10:21 AM
yup minnflyer..i'm trying to say that...=)..wat factors contribute to it hur?
Old 09-29-2003 | 10:22 AM
yup i do understand that woody but why is that so>
Old 09-29-2003 | 10:33 AM
basicly its all about wing loading, E.G you dont see many transports with a wing span/cord of say a Extra....
the bigger the wing the more lift it gives tie that with a huge amout of horse power and yu can carry more weight...
simply put the biger the wing area the more lift you get hence more weight weight..
Old 09-29-2003 | 10:34 AM
Wingloading is important, and is usually the most important thing for sport flying and such.
However, if you are designing a "heavy lift" plane, then airfoil selection becomes very very important as well. You can also have things like flaps and slats that can really help.
Old 09-29-2003 | 10:41 AM
ekrcflyer's Avatar
By definition "payload" is "the amount of useful load (e.g. cargo, passengers, etc.) the plane can carry". Don't forget - the plane should also "carry" itself .
The total weight the plane can [safely] carry is "dirty weight" of the airplane (including fuel) plus payload. The rest is simple - more powerful engines should allow to carry more payload. Of course there are other factors, e.g. engine efficiency, etc., but I guess this is a jist of it.
In addition, other things being equal - the airplane with less "dirty weight" should be able to carry more "payload.
Old 09-29-2003 | 04:30 PM
MinnFlyer's Avatar
I think the most direct answer to your question is:
It is a combination of 3 things:
The size of the wing (In area)
The Airfoil of the wing, and
The amount of thrust that is moving the wing.
Old 09-30-2003 | 10:27 AM
thanks alot guys..=)
