Remove window from foam plane >
Old 02-10-2022 | 11:52 AM
Default Remove window from foam plane
Hi! Been using the forum alot for the past year without having to post, but I need some help here..
Just bought the E-flite Maul 1500mm, great plane, but the servo leads connections in the wings are driving me crazy... So I decided to put in some harnesses for fast and reliable connections when taking the wings off and on. There is limited space in the wings and fuselage to do this, so I want to do some modifications in the cockpit to go forward with my plan. In order to do this I need to remove the front window, and I wonder how this can be done without causing to much damage? Cut or warmth?
First time poster from Norway, hope someone can help me out.
Old 02-14-2022 | 07:51 AM
jaka54's Avatar
Hej!
Har du bilder på hur fönstret ser ut? Är det limmat ?
Ofta får man skära bort kniv.
Old 02-14-2022 | 12:01 PM
Originally Posted by jaka54
Hej!
Hei! Var det jeg også endte opp med, så nå er alt snart i orden.
Takk for at du tok deg tid 🙂
Old 02-17-2022 | 11:40 AM
Moderator
I understood snart in all of that. I guess that's better than a snit.
Old 02-21-2022 | 02:06 AM
Yeah,sweden and norway have funny languages 😉
Old 02-26-2022 | 01:38 AM
jaka54's Avatar
Hi!
What I wrote was:
"Do you have pictures how the window is fastened/looks like? Is it glued on?
Often you have to remove it with a knife".
