Newbie needs help with Arrows Bigfoot wiring >
Old 11-30-2023 | 06:10 AM
Default Newbie needs help with Arrows Bigfoot wiring
I'm a newbie. I bought the Arrows Bigfoot and starting to think it was a mistake, but I have the plane so onward I try to go.
I'm at the spot where I am connecting the wing assemble and the directions on how to connect all the wires is basically nonexistent. Maybe it's because I'm a newbie. Any help would be greatly appreciated.
On the wing, there are 3 wires
Gear
Flap
None
What do they go to? Gear is interesting because it's fixed landing gear so not sure what that one even does.
Then coming off of the vector control module, there are 2 wires that look like matching connectors to the wing Gear and Flap wires but they aren't labeled. I also am supposed to have 2 y cables but they only included 1 in the kit (on order from Amazon). Even if I figure out how to connect them, if the 2 aren't labeled, how do I know what's what?
ANY help would be so appreciated!
Old 12-04-2023 | 01:42 AM
jaka54's Avatar
You have four servos in the wing.
Two of those goes to the ailerons
Two goes to flaps.
The two aileron servos are both connected together with a Y-harnes
The two flap servos are both connected together with a Y-harnes
These two harnes contacts are then put into the receiver on the aileron resp flaps position.
But...For a newbee flaps are not needed or desirable to use/have.
And most important! Join a club!!!!! There you can get help learning to fly!
Old 04-06-2024 | 09:32 PM
Default Problem solved by YouTube.
Gear
Flap
None
Hi, I can’t post the URL because I’m new here, but for you and anyone else with this issue (and I’ve been Googling in frustration for three days) go to YouTube and check out @FatGuyFlysRC there’s a brilliant video posted 5th March 2024 showing the whole build of the Arrows Bigfoot PNP with receiver and transmitter set-up. Very clear and helpful. Happy flying.
flyboy2610 (04-07-2024)
