Charge lead question. >
Old 02-26-2024 | 07:13 AM
Default Charge lead question.
I have a 2 cell 2700 mha nimh battery pack with no charge leads. Can I just solder a charge lead on the pos and neg wires coming from the battery?
Old 02-27-2024 | 10:01 AM
scale only 4 me's Avatar
My Feedback: (158)
Sure you can,,, But I'm curious,, what are you using a 2.4 volt pack for?
Old 02-27-2024 | 11:57 AM
Bottom line is weight. A buddy of mine who gave me the engine ran his glow ignition system on 1 aa ! It's a learning curve for me so if I see a problem with that size setup then I'll go for the bigger size battery pack. Which by the way will probably be the case. Thank you for your reply. I was beginning to think it was a stupid question about adding a charge lead. I can build but the electronics is a weak point for me in this hobby. Thank goodness for RC sites like these. It helps take some of the mystery out of it!
Old 02-27-2024 | 01:28 PM
Which ignition system are you using?
This isn't a remote glow igniter, right?
