oil removal
oil removal
I am currently recovering an old Tiger 2 that I've had for a number of years. After I peeled the film off the nose section I noticed that the wood had taken on a pink hue probably because of the fuel having caster in it. I tried cleaning it with laquer thinner and acetone but even after this, when I give it a light sanding there's little if any dust from the wood that would indicate some level of oil removal. I don't want that covering coming off. A youtube vidio tip says to use hairspray over oil soaked area. Not sure what to make of it, or what to do. Any ideas?
Yep ^^.
It can be hard to find in stores, but my local Ace Hardware carries it. Not sure if it available at all up in Canada. I make sure to always have a can or two lying around, because you never know when it will become unavailable or you will need it. It also works extremely well for getting stains out of automobile cloth upholstery.
Wiping it with any liquid solvent will just dilute it some and spread it all around, which doesn't really give a net positive result at all.
The hairspray used us essentially just cheap lacquer. It has enough alcohol base to soak into the wood but it doesn't really remove the oil. If you can find it, Balsarite wood prep for film is supposed to work on oily wood. K2R really is the good stuff but if you can't find it submerge the entire nose of the airplane (less engine and hardware of course) in a bag of cornstarch and leave it for a week. You won't ever get all of the oil out so removing as much oil as you can and then sealing the wood is the goal.
take some baking soda and put it on the oil soaked areas and let it sit over night then use a brush to clean it off then put thin ca on the area
OR you could cut out the bad part and make new parts to go back in
