 Removing CA residue from MONOKOTE >
Old 10-03-2003 | 10:55 AM
Kristoph's Avatar
Default Removing CA residue from MONOKOTE
So I'm just finishing up building my fancy new plane. It uses CA hinges and I inadvertantly overshot and got a drop or two of thin CA on my elevator. I wiped it up quickly, but it has left a 'foggy' streak.
Anyone know of a good, safe, easy way to get it off ? Or am I stuck with a dull spot on my beautiful covering job ?
Thanks for the help.
-Kristoph
Old 10-03-2003 | 11:33 AM
Default RE: Removing CA residue from MONOKOTE
Try using a little acetone on a rag, or paper towel, and gently rub. My take a couple of doses of acetone on the rag. The acetone, itself, will not hurt the finish. Hope this works for you.
Old 10-03-2003 | 03:08 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Most brands of CA have a dissolver that will soften up cured CA. I have used this to just the same thing you are talking about. squirt a little dissolver on a paper towel and rub off the CA spots till its gone. Then a little de-natured alcohol to get it all off.
hope this helps
Old 10-03-2003 | 05:21 PM
CA debonder (dissolver) is acetone as far as I could tell. I looked the product safety sheet on <can't remember manufactuers name> web site and it contained acetone. It's not a stinky as acetone, however. I just use acetone.
Old 10-03-2003 | 05:54 PM
Mike_Mc's Avatar
Same as with your fingers. Painfully peel off the glued skin/monkote.
Old 10-04-2003 | 12:33 AM
Most nail polish removers are acetone based so they will work just fine.
