Screw for la bAckplate
Look at the OS manual for the engine, it should have a parts list. you may have to buy all 4 screws, but it should be cheap. You can order it through your LHS or tower.
This is the LA40 screw set:
http://www2.towerhobbies.com/cgi-bin...97&FVPROFIL=++
It says the coverplate (back plate) are 3 x 8 mm screws.
You may be able to get them at a hardware store if they have metric screws, or a local nut and bolt supplier, else the hobby shop.
