 Searching Forums >
Searching Forums
Searching Forums
Old 11-11-2003 | 04:00 PM
Default Searching Forums
How do I perform a search for a multiple word criteria?
I wanted to find out about various surfaces of flying fields and searched on FIELD SURFACE. It searched for every post with either word in it. I tried single quotes, double quotes and square brackets around the expression - no luck.
Any help would be appreciated!
KW Counter
Old 11-11-2003 | 08:21 PM
necorc's Avatar
Default RE: Searching Forums
You need to broaden your search a bit first. On the search page check the "Advanced Search" box. You can then include boolean search terms like AND OR NOT
"FIELD SURFACE" brought up one posting so, you may want to use different terms for surface or perhaps "runway surface"?
Hope this helps, good luck.
