C&G Machine / Balancing !!!!!!!!
Hi,
Ive built a few ARTF planes and have been flying them pretty well.
I decided to buy a GP C&G Machine to check my new plane, i decided to check my planes allready flying if they were right and ive set the machine up correctly and wow they were all wrong !!!!!!!!!!
Ive had to add 50 grams to one and 90 grams to another following the recommend C&G point !!!!!!!!!!!!!
Will this make a big difference to the way the plane will handle now ? i allways thought that thier werent that easy to control, allways seemed light if that make sense ??
Anyway thx for any replys in advance...... i know never to just trust my fingers for balancing from now on
My Feedback: (16)
GA
Now remember this is an opinion!
CG is a starting point only.
Depending on the plane and how you fly, you may want it more nose heavy or tail heavy.
I normally fly with reduced elevator throws and slightly tail heavy.
SO for me, I am always aft of the CG point. Just remember that for all planes where the take is forward of the CG point, that it will always be nose heavy when you first take off. THen as fuel burns your CG moves back the the preset point.
Just fly the plane and move the CG forward or backward to get the plane to fly the way you like.
ORIGINAL: DragonHeart
Hi,
Hi,
Beginners are encouraged to have a forward CG, makes the plane stable and forgiving. Acrobats tend to have the CG back, so they can do more radical moves.
The most efficient CG is that where the plane's CG is immediatle above the center of lift of the plane for the speed the plane is flying at. All other CG's require some form of intervention from the elevators to keep the plane trimmed (i.e. if the CG is forward of the CofLift, then you will need up elevator to keep level). Any control input other than "neutral" causes extra drag, reducing efficiency.
basically, the CG is always a compromise between efficiency, stability, and manouverability. Beginners should start with a more forward CG, experts with lightning reflexes can have a rearward CG.
gus
Yes thx for all the info,
They were tail heavy i have OS46LA's in my planes and ive been told that this is a really light engine.............
