Lazy Bee
My Lazy Bee's always end up too heavy :-(
Does anyone know what a 40" Bee should weight before you add the motor, fuel,battery,RX and servos?
If I had this starting weight, I could analize as I added. I know what I should end up with but I need to make sure the fuse and wing are within specs.
I'm not sure what the weight is suppose to be. Are you doing anything different from the plans? What about your wood selection? Given the Bee's are mostly stick construction I don't know what you could do to make it so heavy.
