TT F90S 4-Stroke Engine Question
OR
Gotta first 4-stroke newbie question for you guys... I am just now mounting my TT F90S 4-stroke engine in my 4* 60 size and noticed a breather fitting on the lower front of the engine beneath the crank shaft. I've identified the fuel inlet (carb) and the muffler fitting for fuel tank pressurization but what is this fitting for? The TT manual doesn't explain it as far as I can tell.
My Feedback: (17)
TX
It's the crankcase drip. Simply run some fuel tubing from it down to the oval notch in the fuse that's just under the engine. That's what I did. If you need some pics of it, let me know.
I'll be happy to post some.
TX
Also that is the vent you'll add afterrun fluid in after each day of flying if you want the engine to stay rust free and live to be an old age.
