 Flaperons? >
Flaperons?
Flaperons?
Old 12-05-2003 | 05:27 PM
Iceman30's Avatar
My Feedback: (14)
Default RE: Flaperons?
i think your superstar has only one aileron servo though ?? If it is the Superstar Select trainer.
Old 12-05-2003 | 06:21 PM
cappio777's Avatar
ORIGINAL: combatpigg
I'll bet the F4-E has the elevator coupled to make this control sceme work .
No coupling there.
Old 12-05-2003 | 06:26 PM
ORIGINAL: cappio777
No coupling there.
Even if it did have coupling, that doesn't mean anything. Most aircraft need some type of elevator trim adjustment when the flaps are lowered. That does not make an elevator/flap mix flaperons. It makes it elevator/flap mixing and nothing more.
Old 12-05-2003 | 06:34 PM
cappio777's Avatar
ORIGINAL: CafeenMan
ORIGINAL: cappio777
No coupling there.
I just wanted to see three quotes in one post.....[sm=stupid.gif]
Old 12-05-2003 | 06:35 PM
ORIGINAL: cappio777
ORIGINAL: CafeenMan
ORIGINAL: cappio777
No coupling there.
When quotes are coupled like this are they Quoterons? Quotervators?
Old 12-05-2003 | 06:41 PM
  #31
cappio777's Avatar
ORIGINAL: CafeenMan
[When quotes are coupled like this are they Quoterons? Quotervators?
Thats a good question! [sm=lol.gif]
Old 12-05-2003 | 06:43 PM
  #32
ORIGINAL: CafeenMan
ORIGINAL: cappio777
ORIGINAL: CafeenMan
ORIGINAL: cappio777
No coupling there.
Quintquotelets!
Old 12-05-2003 | 06:47 PM
  #33
ICE_MAN's Avatar
I know it only has one servo but if i peel of the covering and add to rectangles of balsa between two of the ribs to where the pushrods still line up the i can conect them through a y-harness
Old 12-05-2003 | 07:28 PM
  #34
combatpigg's Avatar
Tell me something guys, when you're out there doing climbing inverted flatspins with your flaperon equipped stunt ships, do you like to be coupled or uncoupled?
Old 12-05-2003 | 08:33 PM
  #35
Depends... is said stunt ship equipped with slatervaterons to establish laminar flow at the critical pressure boundary? Or are we talking your typical morris the knife?
Old 12-05-2003 | 09:11 PM
  #36
If it hasnt already been pointed out then I would like to say that combatpigg is right when he defined flaperons. I didnt really have time to wade through all of the jargon and technical babble. It really doesnt matter what your dictionary may or may not say but take it from a member of the 3D world (where we do a lot of mixing). Flaperons = Ailerons moving opposite of elevator (i.e. elevator goes up then both ailerons kick down. Spoilerons = Ailerons moving in the same direction as the elevators (i.e. elevator goes up then both ailerons kick up).
If you still dont beleive me I will have one of the big sponsored 3D pilots come in and set it all straight.
Old 12-05-2003 | 09:15 PM
  #37
combatpigg's Avatar
ICEMAN! It seems to me that you could peel the covering on each wing panel and drop in a couple{there's that word again]servos. Reenforce both ribs that you are installing the servo between with some balsa scrap, and use some spruce or any other kind of hardwood for the servo mounting rails that bridge between your beefed up ribs. the rails only need to be 1/8" by 3/8" thick to do the job in a 40 size ship. CAFEENMAN! Don't know what slatervaterons are, and when I posed the question, and showed your thread to the boys at the club meeting, all I got from the guys in the peanut gallery were some very impressed looks.[X(][X(][X(] Keep up the good work, guy!!
Old 12-05-2003 | 09:20 PM
  #38
ORIGINAL: southern_touch9
I don't even understand why you are debating this. You are absolutely wrong. Where do you people get the idea that flaperons have anything to do with elevators??? That's utter nonsense.
Anyway, several people have provided plenty of information on what flaperons are. Believe what you want.
Old 12-05-2003 | 09:21 PM
  #39
combatpigg's Avatar
SOUTHERNTOUCH9!! Where have you been guy? I've had to hold these non believers off alone. They are correct, when you take only the purest, literal translation. I would hate to know what they think about,"Spare the rod, spoil the child"!
Old 12-05-2003 | 09:26 PM
  #40
From Futaba (the same people who make the manual that was offered as proof):
http://www.futabarc.com/faq/faq-9c-q514.html
I am setting up flaperons on my 9C. The flaperon function works great for the ailerons, but I can't seem to operate the flaps. What am I doing wrong?
Nothing. The stock setup of the flaperons is so that the ailerons are operated normally, and then if you want to operate them also as flaps you will use airbrake or a mix to activate the flaps. If you want to be able to TRIM your flaps, or adjust them with a dial, go back into the Advanced menu, go to FLAP-TRM, make it active and set the desired % of flap travel on a knob. Note that the flaps will go both up and down on whatever knob is assigned to channel 6.
Old 12-05-2003 | 09:31 PM
  #41
More links of interest:
http://www.mindspring.com/~cramskill/flaperon.htm
http://home.epix.net/~jlartin/flaperons.html
http://www.avidair.com/features.html
More from Futaba:
http://www.futaba-rc.com/faq/faq-9z-q175.html
What are twin aileron servos and flaperons? Are they beneficial?
When a manufacturer or modeler talks about twin aileron servos, they usually mean the model has one servo operating each aileron on the wing and that the two servos are plugged into separate channels on the radio. Twin aileron servos are a very beneficial set up which allows the modeler more precise control of the aileron response of the model, as well as offering 'flaperons' -- the movement of both aileron servos in the same direction at the same time to act as flaps.
Old 12-05-2003 | 09:48 PM
  #42
Im here to save the day combatpigg. I sent some PM's out to some of the top pilots in the Nation. If you dont beleive the guys who fly in XFC, WAFC, Tuscon shootout, etc. then who are you going to beleive? Webster never flew an R/C airplane.
CafeenMan,
If Futaba defines flaperon as you have posted above then there is no doubt that is known as a flaperon. However you should keep in mind that with many words in the english lang. there is more than one definition. Like it or not combatpiggs definition is accepted by all of the pilots in the 3D world and by the majority of the R/C community.
Old 12-05-2003 | 09:58 PM
  #43
CafeenMan,
I personally don't care what Futaba says about flaperons. The only reason I dug up the Futaba stuff was because earlier CombatPigg used a reference from a Futaba manual as proof that flaperons include elevator. So either he is wrong about the Futaba manual or Futaba is contradicting itself. As I said in my first response to that, the Futaba manuals have a lot of errors in them.
Second, "most" of the r/c community DOES NOT think that elevator is part of flaperons. Anybody can make a statement like that, but you didn't actually go out and do a survey to find out what "most" people think did you?
I've been doing this for over 30 years in a lot of different places and until this thread I've never heard a single person mention elevator as being part of the flaperon equation. That's just something that your circle of people misunderstood and are now perpetuating and spreading bad information. In other words, you're doing a disservice to anyone who looks to you for information.
Old 12-05-2003 | 09:59 PM
  #44
combatpigg's Avatar
SOUTHERNTOUCH9!!! I just put you in my will!
Old 12-05-2003 | 10:01 PM
  #45
cappio777's Avatar
A little argument about "surfing" happened at a computer forum a while back. A couple individuals, that I believe never seen the ocean, kept saying that "surfing" is a term copied by the bums that ride waves on the ocean from the internet "surfing" term. The answer is more logical than our topic at hand but it demonstrates that it depends on the "circles" some individuals have been most of their life and how easily it can slowly change the real meaning of some terms.
Another good term that has different meaning for many people is "morphing".
Old 12-05-2003 | 10:02 PM
  #46
When you can't be right, you can always start a support group.
Old 12-05-2003 | 10:10 PM
  #47
combatpigg's Avatar
Cafeenman, My 10 year old daughter uses the same exact line. You guys must watch a lot of the same TV shows.
Old 12-05-2003 | 10:13 PM
  #48
Everybody can't be wrong.
PS. I don't watch any tv at all. Television rots brains.
Old 12-05-2003 | 10:24 PM
  #49
Futaba contradicting themselves NEVER!!!
Thats why I fly Hitech
If you have never heard of it then you dont browse the 3D forum much (though they mainly talk about spoilerons b/c they are more effective for most 3D stuff). Here are a couple of links.
http://www.rcuniverse.com/forum/m_12...tm.htm#1298078
http://www.rcuniverse.com/forum/m_84.../tm.htm#847772
Now I am going to have to go dig through Futabas setup errrrr [>:]
From a couple of the websites I have been reading most of them spell Flapperons with two p's.
Old 12-05-2003 | 10:38 PM
  #50
combatpigg's Avatar
SOUTHERNTOUCH9!! Confuscious say, "Never argue with a guy who has laminar flow over his critical pressure boundaries!", Regards, COMBATPIGG
