build question
Hi, Im building a flair puppeteer and its nearly done. the covering is finished and I now need to attach the tail plane and rudder to the fuselage, Im sure I know how to line it ul etc but wondered what was the best way of attaching it.... is super glue strong enough ? or should it be attached somhow else
thanks for any help
thanks for any help
All i have used on any applied epoxy joint is
6 min epoxy. I have neeeever had a bad joint.
I have done this for 33 years.
30 min epoxy will give you more working time
but is not a must.
but is not a must.
Yes, you CAN use 6-minute epoxy, but if you're like me, a problem will arise at the last minute that causes you to break stride. next thing you know, you're scraping off the epoxy before it sets. The 30-min stuff gives a better bond, and allows extra time for unforeseen problems that may creep up.
