What spinner size should i use?
Im going to buy an OS 46 fx with an APC 12x4, what plastic spinner size should i use? My TT .42 engine uses a 2, 1/4, should i use the same size??
Tks
Tks
QC, CANADA
RE: What spinner size should i use?
It's also a quesin of what looks good on the plane! Most kits recomend a spinner size, to 'finish it off'.
the cut-outs for the prop can (and usually always do) be cut larger, to fit larger props. Don't cut a prop to fit the spinner!!
