Receiver help
4. Notice that the 4th one is "4/B", B for battery. Use a Y harness to connect both the battery and a servo. Actually, it doesn't have to be that channel; the power connections are all connected together.
What plane are you thinking of putting this in?
BTW it helps if the subject of a message actually tells you what the question is about. "help!!!!" could mean a lot of different things, and some people may just skip over it and not bother to read the message.
LA
4 channel with as previously noted, the 4th channel using a Y connector to add power.
Ditto on not using help. Have a nice day.. [img]i/expressions/face-icon-small-smile.gif[/img]
