 Can I use the PA-2 Copilot with RD-6000? >
Old 12-28-2003 | 07:20 AM
Default Can I use the PA-2 Copilot with RD-6000?
Yoram
Old 12-28-2003 | 07:52 PM
Default RE: Can I use the PA-2 Copilot with RD-6000?
Check to make certain that the wires on the servos match the input wiring for the co-pilot. Airtronics used to have a different wiring arrangement from everyone else. I don't know if the new ones are different, or not.
If all the wiring matches up, i.e. signal wire, power and ground wires in the same locations between the co-pilot and the servos/receiver all should be well. The co-pilot was designed to work with any radio.
Old 12-29-2003 | 01:34 AM
Imac Kiwi's Avatar
The Airtronics RD 6000 comes with "Z" connecters. These are the same polarity as mainstream radio sets.
Alan
