Spinner Bushings?!? What?!? Do I have to glue these in?
MA
The Spinner Bushings were included with my trusty old (er, rather, incomplete) Tiger II and spinner.
The spinner itself does not fit my engine. It included Spinner Bushings (little nylon affairs that shrunk the size of the hole in teh spinner).
Should I buy Ball Bearings?!? I'm confused.
Do I glue the Bushings into the spinner, or do I just put them on?!?
It came with five bushings, from big to small holes. Should I use the smallest hole that (if I use tons of force) will fit into my engine, or should I use teh bushing that fits the best (not 2 loose, not 2 tight)?
Thanx!!!
PS Skysport 6 (6YG) No Longer For Sale!!!
Thanx!!!
RE: Spinner Bushings?!? What?!? Do I have to glue these in?
Yep. Just use the bushing that fits snug, but not too tight. All you're doing is "filling in" the gap between the spinner backplate and the prop shaft. It's not critical the way some things are. Bushing is also a bit confusing, but in this case it's nothing like a bearing. (The bushing does not allow anything to turn as a bearing would.)
Definitely going to the field tomorrow if you can get a ride. Probably 11:00 to 2:00, or there abouts.
Dennis-
Dennis-
MA
Aww Mann...
Sorry, DB, didn't make it, AGAIN!!!!
My parents don't really have too much time to take me...... Ahhh, o well.
Sorry...
Don't we all like sunny days?!?
PS DB wot planes do u have? You said you trained on a PT40, do u still have it? or any trainer?
Sorry...
