Patriot jet CG
WI
Patriot jet CG
Hi all I was wondering if anyone knew where the CG is on a older patriot jet prop airplane? I have aquired it through a sale but have no idea how far back from the leading edge to balance it. It was said to be a GP patriot but is not the newer version with the simulated ram air version. Thanks and any help would be greatly appreciated.
RE: Patriot jet CG
My plans from 1992 show 8 to 8.75 inches from leading edge at dowls. I'm not sure what you mean by the newer version with the simulated ram air version. This one has simulated intakes on both sides of fuse and it is the same as GP is making today. I have 2 new kits that I purchased last fall and as far as I can tell, nothing has changed since it was released in late 1991 or early 1992.
George
George
