 Starting planes with spinner nuts >
Old 01-30-2004 | 07:59 PM
KingSalomon's Avatar
Default Starting planes with spinner nuts
How do you start a plane with a spinner nut? It doesnt look like my starter will fit over it well... thanks... -Dan
Old 01-30-2004 | 08:08 PM
Default RE: Starting planes with spinner nuts
Turn the rubber cup around so you'll be using the 5/8" hole.
Old 01-30-2004 | 08:32 PM
That Works? It looks a little too thin, like it would wear out quickly, or not have enough pressure... But I'll give it a try...
Old 01-30-2004 | 09:10 PM
What !! Do you have an indoor flying site ? I need to be putting a set of plane ski's on tonite. We're in line for 10" + Saturday nite.
There's an aftermarket co. that sells inserts with a smaller tapered cone. The flat back reversed cup will last you a couple of seasons.
Old 01-30-2004 | 09:17 PM
depfife's Avatar
My Feedback: (14)
Turning the cone around will work, or you can purchase one like this.
http://www2.towerhobbies.com/cgi-bin...?&I=LXFT97&P=0
Eric
Old 01-31-2004 | 01:09 AM
alright... thanks
Old 01-31-2004 | 01:43 AM
I've got this one:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFT98&P=0
The picture shows the back, the other side is similar to the pink one but with a smaller hole. It seems to work fine for the rounded Harry Higley prop nuts. I've just discovered one problem though, I can't get the bu%%er off the starter cone... maybe the pink one is more flexible....
Old 01-31-2004 | 01:44 AM
Banned
Put the skis on... its fun to fly off snow. I used to do it. (may want to use a small cheapie tobaggan as a take-off dolly with 10 inches fresh powder... Darn plane may sink in the snow before take-off otherwise.)
