wing joiner play...
MN
hey, i am building a Great planes piper cub 40 ARF... There is quite a bit of play in the wing joiner/wing joiner slot, is this ok? or, what should i do?
My Feedback: (16)
GA
No, this is not good. You need to build up the area to tighten the joint.
ORIGINAL: KingSalomon
Define "Quite a bit".
Can you wiggle the joiner? If so, how much?
Is the slop from top to bottom, or front to back?
Even though the fit may not be snug, it may still work if the gap isn't too big, in either case, a tiny shim against the lesser side of the pocket will force the joiner towards the Major (Spar) side. That's what's really important.
