 Plans for converting to taildragger. >
Old 02-07-2004 | 06:40 PM
ICE_MAN's Avatar
Default Plans for converting to taildragger.
does anyone have or know where to get plans to convert a superstar 40 arf into taildragger?
Old 02-07-2004 | 08:41 PM
My Feedback: (13)
Default RE: Plans for converting to taildragger.
You don't neet plans, really. Just move the main gear forward - about one inch ahead of the CG. Put a tail wheel attached to the fuselage with a connection to the rudder so the tail wheel follows the rudder and you're all set.
Old 02-08-2004 | 01:03 AM
skypilit's Avatar
I have just started to convert a duraplane to tailwheel and they have told me in these posts that if you are training on using a tailwheel, the centerline of the main gear should be lined up with the leading edge of the wing.
Dave
Old 02-08-2004 | 01:38 AM
That is not always true. What ALWAYS works is moving the main gear a minimum of 1 inch forward (towards the nose) of the center of gravity. The gear can often be moved farther forward to better ground handling.
I've been building for over 30 years, and this hasn't failed yet. If you look aroud a bit, you will find many planes with the main gera out of alignment with the leading edge of the wing. By the way, which leading edge should the gear align with on a biplane? Or Triplane? How about a Canard? See what I mean.
Old 02-08-2004 | 01:51 AM
CP140's Avatar
When you're done the conversion, don't forget to check your CG before trying to fly it...make sure it's where it was before you started moving things around and bolting on a tailwheel!
Old 02-08-2004 | 10:54 AM
ICE_MAN's Avatar
What if i just moved them to where the front rubber band hold down dowel is. Slightly in front of leading edge?
