 PCM reciever and standard servos? >
Old 02-18-2004 | 12:20 AM
Skribnod's Avatar
Default PCM reciever and standard servos?
Can I use standard servos on a PCM reciever or do they have to be didgital? Thanks
Old 02-18-2004 | 12:22 AM
Default RE: PCM reciever and standard servos?
ORIGINAL: Skribnod
Yes: You can use standard servos or digital servos with pcm receiver.
Old 02-18-2004 | 01:05 AM
Skribnod's Avatar
Can I use digital servos on a standard reciever?
Old 02-18-2004 | 01:09 AM
YES!!
Old 02-18-2004 | 01:52 AM
Skribnod's Avatar
Thanks for the info. I appreciate it.
Old 02-18-2004 | 09:08 AM
My Feedback: (55)
You can use digital servos on some FM receivers. Horizon's JR technical
support says they work with some receivers but not all. Call and they
can tell you which ones work.
tommy s
Old 02-18-2004 | 06:58 PM
My Feedback: (16)
This must be a JR specific issue.
Old 02-18-2004 | 09:19 PM
Banned
The same servo positioning output comes fromt he PCM RX as from the PPM RX.... The difference in the digital vs the "standard" servo comes AFTER the position desired is determined.
Plug 'em in... they work.
