 Engine Test Stand >
Engine Test Stand
Engine Test Stand
Old 03-01-2004 | 02:55 AM
reapr's Avatar
Default Engine Test Stand
I have some scrap 1X4's 2x4's 2X6's and plywood. Could anyone recomend a cheap and easy way to make one with some wood deck screws? Pictures and plans appreciated.
Old 03-01-2004 | 04:21 AM
Banned
Default RE: Engine Test Stand
Essentially make a sawhorse. then a ply plate with a cutout for the engine to fit in. (different ply plate for each engine) Add a snaked cable type throttle linkage. (the bends will tend to hold the throttle where you put it.)
Essentially... anything that holds the engine firmly will work. I do all of my engine testing with the engines mounted to an aircraft. the test stands are just an extra mounting and dismounting process. Tie the plane's tail to a post... and you can let the engine run for break-in.
Old 03-01-2004 | 06:24 AM
My Feedback: (16)
I have one that is designed by a guy in florida. I am going to post in on my site when I get chance.
Old 03-01-2004 | 03:46 PM
I saw one put out by VMAR that looks pretty nice and is inexpensive.
It is reviewed in the RCU Magazine on this sight.
VMAR isn't well thought of in this neighborhood, and the price scares me a little.
However, I did get some good ideas from it.
Good Luck,
KW_Counter
Old 03-01-2004 | 04:19 PM
Kmot's Avatar
My Feedback: (24)
Here's mine.
ID:	106732   Click image for larger version
