Control surface deflection?
WA
How much deflection in degrees do you need for the rudder, elevator and ailerons? This is a trainer but I will want to fly it to it's fullest capability and will be increasing throws as my skill level goes up. What will be the max throws I will need? I know this is tough but I'm making a compromise between hinge gap and deflection. I can seal hinge gap, I can't easily add deflection.
Thanks all!
Thanks all!
AZ
Hi spokman,
Now I'm new to R.C.'ing Anyway I bought an Avistar and my throws are as follows.
Ailerons..5/16" ea. way Rudder..3/4" ea. way Elevator 3/8" ea. way.. Remember
the streeing should have VERY little movement, At least that what I've been told
my trainer said if you can do a 360 in 15-20' thats good enough!!
They seemed really small movements.. But the plane sure flys great!!
AZ
Hey spokman,
You could do that... I remember on my Avistar, I went the wrong way on the
control horn which gave me a lot more movement.. And while flying it, It reacted
alot faster!! But it was also harder landing....
I would stick with the manuel's settings first!! You could always increase later to
suit your needs!! Remember.. More is not always better!!
WA
You have to understand I'm not talking about control rod settings. I'm talking about max deflection of the glued surface and how much gap to allow to get a certain amount of throw. I'm definetly setting the throws to those suggested by Sig.
CO
Hi You want to keep gaps to a minimum! Air leaking through large gaps cause the controls to be less effective! If they are more than 1/16" , They should be sealed with covering or clear packing tape. Also at high speed, as in a dive, large gaps can lead to flutter!
WA
Everything went well! I have plenty of deflection and my gaps are small. My rods are supported every 6 inches or so at every bulk head. I'm also going to run steel rod from the control horns to the first supported joint. I'm sold on Robarts and epoxy for them. Thanks all!
