3D!!!!
All 4. First you have to get the plane pointed up. Then you have to modulate the throttle so it stops going up and make sure it doesn't come down. Then you have to work the elevator and rudder to keep the tail underneath the engine. Once you get the tail in the "sweet spot" it sorta locks in. You can either let the plane torque itself around or use opposite (right) aileron to keep the top pointed at you (a good thing when you're just learning).
GOod luck!
GOod luck!
NY
wow for some reason every time i try it on the sim it stall and crashes, damm it looks hard and its even harder to do, and im just on a sim! lol Ok know once you got it hangin on teh nose how do you get it out of there??? Every time i give it full throttle and give it up elevator it stalls and crashes like 2 feet of the ground. lol
GA
ORIGINAL: GTac01
Use an acrobatic airplane, like the sukhoi or the extra. You cant just hover with any airplane. Keep trying, and you'll teach yourself. Its pretty hard tho...
ORIGINAL: GTac01
ORIGINAL: Lightfoot
Which Sukhoi or Extra do you have? Some of them perform well but don't quite measure up in 3D maneuvers.
ORIGINAL: GTac01
GTac01, Seeing as how you only learned that this sport existed a month ago, please refrain from giving advice about things which you know nothing about.
GTac01... Use an acrobatic airplane, like the sukhoi or the extra. You cant just hover with any airplane. Keep trying, and you'll teach yourself. Its pretty hard tho...
Im speachless [
