NexStar landing gear question
NJ
I'm putting in the landing gear, and it one is sticking out further than the other. Looking inside, it appears they are in the correct position. Is this normal ? I was thinking this is to compensate for torque ???
NJ
RE: NexStar landing gear question
Heh heh, you were right I was afraid to break something so I wasn't pulling on it hard enough. It cam out though and I put it back and it locked into place, symmetrical to the other one. Thanks [sm=thumbup.gif]
AK
Hey, I actually helped somebody.
One thing I noticed with mine is if you push in the holes underneath the airplane to take the landing gear out, then when you go to put them back in the springs wont engage, and the landing gear pull right back out. They wont lock into the holes in the landing gear. How you fix that is take a long screwdriver and push the tabs back into place from the inside of the plane look inbetween the servos and you will see what I'm talking about.
NJ
Great, I'll keep that in mind for future reference. Thanks again Northriver21 !
MitchH2004[sm=thumbup.gif]
NJ
Thanks. No, not yet. I'm giving myself a few weeks flying the Real Flight simulator on the computer before heading over to the club. I have a an AMA certified instructor who is going to show me the ropes. I just want to get used to flying the plane towards me and not moving the sticks the wrong way.
MA
hEY MITCH do yourself a favor,remove the air brakes and afs from the start while you have the instructor with you i did and saved myself some time in learning to land with out them,but dont remove the wing tips.its a fun flying plane! you might want to add a muffler extension its made of rubber and it aids on having to have to clean the plane up at the end of the day helps direct the flow,also if your going to use a power starter you might want to add a aluminum nose cone the plastic ones when wet from fuel tend to spin alot when starting and the prop losen up when it kicks back, most hobby shops keep both products in stock......good luck and have fun......BILL
If you remove only the flaps and not the wing tip droops, then you'll have to significantly alter the trim of the elevator. Check the instruction book. It tells you of the effects each has on the model. If you remove the flaps, then you'll have to compensate for a strong nose-down tendency.
ORIGINAL: northriver21
Mitch! Fancy finding you here!
Glad you sorted your gear out, could have been embarressing later, or a real skills test
Had my Nexstar up today on its maiden flight. Posted details and pics at: http://www.rcuniverse.com/forum/m_16...tm.htm#1690950
Careful with the fuel tank issue, seems I may be second at our club with the problem, though first guy fixed his and I don't know what the answer was! [&o]
Catch u later mate,
Kev.
Catch u later mate,
Kev.
Hi there Nexstar owners,
Remember to check the landing gear to see if there locked in place everytime you fly. I went to my local field today and was getting ready to fire up my nexstar when the landing gear slid out of its harness. Good thing I noticed it before it was airborn. I suspect a hard landing I had yesturday was the cause?? Everything else has stayed together except for a loose screw where the motor mount meets the firewall. I have about 20 flights on my nexstar and just recently removed the speed brakes and wing droops. Roll rate is much quicker and can even do outside loops now. I tried one before they were removed and the nexstar would not even start to climb inverted. Having a lot of fun with this aircraft.
JVK
JVK
NJ
Hey Kokpit ! Just saw your reply a month after you left it !! For some reason I cannot explain, I built my plane then went into a R/C car frenzy. I actually just got in touch with a trainer yesterday and going to give him a call this week to plan a meeting. I'll let you know how it goes. (I've been avoiding the AGW for a few months, ever since that virus thing went around)
<S> Mitch
<S> Mitch
My Feedback: (34)
Not to disagree with some of you, but I thought the speed brakes were great! It slowed the plane down so even full throttle wasn't too fast. And with the brakes on, this bird couldn't stall which made my day when some newbies were practicing their first landings!!!!
Jerry
Jerry
