easy fuel valve
easy fuel valve
I need to know if i'm doing this right. One fuel line goes from the tank to the fuel valve nipple and the other niple on the fuel valve goes to the engine? Thanks
RE: easy fuel valve
Yes, that's right. Make sure you get the nipples on the valve connected to the right thing, it's not symetrical. If you hook up the "tank" line to the engine and vice versa, you won't be able to fill your tank, you'll just flood the engine instead.
RE: easy fuel valve
The line that comes from your fuel clunk is the one that goes to the needle valve on the engine. Then you will need a 3d line to the nipple on the muffler. [8D]
