Any Sugestions?
What type of adheasive should I use to bond laster cut pieces together with? I've looked around and seen alot of different glues, but I still don't know what to use. Could anyone sugest what is the strongest and least brittle adheasive to use for this situation?
Banned
I vote for the yellow, water based wood glue. [img]i/expressions/face-icon-small-wink.gif[/img] (for most joints)
Some places, CA is a better idea, some places... epoxy.
I use CA on all of my parts. On the laser cut parts, if you are worried about the burnt part of the wood, just lightly sand off the discoloration, it'll be fine.
AZ
I use Ca for balsa and epoxy or carpenter's wood glue for plywood or balsa to plywood joints. Never had a failure except when I tried to assemble a spruce fuselage frame with Ca.
Thank you all for your sugestions on what glue I should use, it really is going to make a difference for my JU-87. I will post some pictures of it when im finished on this forum.
