 Alternatives to the AP .15? >
Old 05-05-2004 | 06:32 PM
Default Alternatives to the AP .15?
Hi guys,
I'm looking for alternatives to the .15 AP. Are there other engines in this size that are possibly lighter or more powerful?
Thanks in advance!
Old 05-05-2004 | 07:35 PM
Default RE: Alternatives to the AP .15?
I believe that Fox still makes a 15. They were powerful engines. I believe that OS also makes a 15. And lastly I believe that Magnum also makes a 15. MVVS makes I believe a 12 that should be real strong. Give a look at these. This is according to memory.
Mark Shuman
Old 05-05-2004 | 07:51 PM
Thanks, Mark. [&:]
Old 05-06-2004 | 01:10 AM
Banned
Stay away from the LA. If it has a blue case... its a rock, not an engine.
Old 05-06-2004 | 01:53 AM
I was actually going to buy one tomorrow! Why do you say that? There isn't an FX version of it, though there is a CV-A or something, but it is more expensive and has only a marginal increase in BHP. Can you convince me otherwise?
Thanks!
Old 05-06-2004 | 08:57 AM
Banned
Inconsistancy. If you could depend on them to be good or bad... then at least you could depend on them.
I've seen a couple of LA's that worked fine. The first LA series engine I saw at the field... I was wondering why people were complaining about them on the net... it had good power... it started right up straight from the box and was able to be adjusted for stable idle within 2 tanks of fuel. It produced the power you expected from the size engine too.
I've now seen more that had problems than ones that worked.
The one I have been fighting with the last month simply refuses to give as much power as an engine half its size. A .46 that struggles when turning a 10X4.[:'(] forget putting a 11X7 on it (which it SHOULD be able to turn...at least 11,500) I have SEEN LA.46's turn 11X7's... and do fine.
Its not lack of adjusting skills... I have been tuining model engines for 30 years. I'm very familiar with the air bleed carbs. I have cured the problems other people were having with LA engines!
Old 05-06-2004 | 01:27 PM
I fly a lot of .15 powered planes in combat, and there are a lot of .15 engines out there in various price ranges with various strengths and weaknesses.
All of these engines put out more power than a stock AP Yellow jacket.
OS makes two .15's, the CV-A and the LA. The LA is ok. It acutally turns an 8x3 prop with some surprising power, it's a low rpm, high torque motor, so don't put a small prop on it. Oh, it's a "MUST" to take the baffle out of the muffler, or at least drill it out. Makes a HUGE difference. It also has problems with the plastic backplate and the all the screws on it are cross point, not hex, and pretty cheap. In the combat community, guys often replace all the screws and some guys get metal backplates (the old OS .15FP backplate fits). If your OS LA starts running funny all of a sudden, it's most common that the backplate is leaking or cracked.
The CV-A is high dollar, but very high quality, with solid power. If you can afford it, get it, there are no downsides to this engine. (it's not legal in SSC class combat though, not that you need to worry about that)
The Magnum .15 is a pretty good running .15, but the carb needs attention. If you go with the Magnum, you should take a quick look at the "Magnum Notes" on my website at www.MidAtlanticCombat.com. If you don't take care of the carb, the engine will run fine at first, then go to hell, mostly because of the O-rings on the high and low speed needles. I have 4 Mags, and they all run just fine. Some folks have had problems with the front bearing getting dirt in it. I haven't had to do a bearing change yet, but the bearings aren't shielded as well as some other motors. Bonus: global hobbies does a great job supporting these, and spare parts are cheap and easily available.
Megatech .15, this is a clone of the CV-A. Great power, maybe best bang for the buck out there. Not well known, sometimes hard to find, and who knows abott spare parts. I did see one blow up a bearing in flight once, but that engine was turning some serious RPM, so I don't think it was normal.
Norvel makes two .15's a ball bearing and a bushed .15. Both are screamers, but both are kinda odd. You need to get a special head wrench to work on them, and if you don't have the wrench, the head will losen up on you. The carbs have iffy quality control on them, and the muffler attachment method sucks (spring clip, not screws). But they SCREAM for the guys who know how to get them running right.
Thunder Tiger makes a .15. I haven't seen much about it, but it appears to be reliable enough, though not as powerful as the OS LA and the others above.
Fox and Enya make .15's. Both have good reputations, but I haven't seen them in competition, so I can't really say for sure how they stack up, and if they have any problems.
There are also a collection of high dollar .15's used in FAI competition, but they are pretty ignoreable for this forum.
Old 05-06-2004 | 03:28 PM
Thank you for the post, Montague. It seems all of them have their up sides and their downsides, and I am still deciding. Would you recommend the .15 AP? How inferior is it in terms of power? Will it spin a 7x4?
Old 05-06-2004 | 03:38 PM
I haven't seen the AP in person. But I've talked to a couple of guys who have them. It's under powered, so no, I wouldn't recommend it.
Btw, right now, the Magnum line of engines are on sale. You can get a Mag .15 for $44. That's hard to beat, even with the carb issues.
